Yes that also would point towards a bad control board.
The control board looks expensive so I do not know if I would put those dollars into this unit.
Unless you really like the unit and it is in very good shape.
On thing is that if you get the board from AppliancePartsPros and it does not fix your problem you can return it.
Please see their return policy.
Thanks for the response denman. Yes, the control board is a bit pricey however a new range/oven is not really in my budget at this time… And you know how the story plays out… new oven range leads to a whole kitchen remodel… LOL!!
Being able to return the part is fantastic… I’ll check out the policy.
Replacing the control board appears to have fixed the problem. It was pretty straight forward to install except for the ribbon connection from the button panel. Took a bit to figure out that the ribbon had no connector on the end and that the ribbon would slip into the connector on the new board and then be clamped shut.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
