The heat has stopped working on this dryer. I am fairly handy and am wondering if it is likely the heating element and if so, is it something I can buy and find instructions to replace.
Gene has helped me with my fridge … any help here? =)
First I would check the power.
The controls and motor run off of half the line (120 volts) but you heating element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on. Be careful as 240 volts is lethal !!!
