Kitchenaid Superba Thanksgiving Failure
We were getting ready for the Big Thanksgiving Feast, Cleaning the top oven of our Kitchenaid Superba Double Oven. It went through the cleaning cycle for about 3 hours, and it died before it was complete. It went through at least 2 hours and 15 minutes the last time we looked at it. It was extermely hot when it just completely shut down on us. Tonight we replaced the Thermal Cut out Fuse thinking that was the cause of the shut down, but there is still no power going to the oven. All the breakers were checked, and no problems there. There are 4 ?diodes? or ?resistors? on the right side of the control panel (facing from front of oven - behind smaller lcd) that have brown coloring around the bases looking like they may be fried. Is this the problem, or is there something else we should be looking at?
Which fuse did you replace - control panel fuse or oven shutdown fuse on the back?
Is the display blank?
Gene, we replaced the shut down fuse on the back. jls2008
Gene, wondering if you had come across that part # yet ? the wife is getting restless with out her oven. Thanks jls 2008
I just received it. The part number for the control panel thermal fuse for your oven is AP3110028
