LG Front Loader Lasher
The code on the front display panel reads LE. The code indicates an overload in the motor. Is there any testing procedures to ensure that the stator assembly is the problem or something else?
there is a part called a hall sensor on stator, its white plasic +clipped on, i think there is 2 wires going to it, LE usually means Hall sensor failed
