our maytag washer keeps shutting off at each cycle. Someone told us it was the door lock. Need help tying to figure out what parts are needed in the door lock and control panel.
Thank you
Thank you
Hi,
Been dealing with a different issue with my MAh3000AWW - you need to provide more details of your problem - like settings - does in not do the final high speed spin and the cloths come out wet/real damp? The wax motor and the main control might need to be replace if that is the case. Hope that helps.
