Dryer runs but doesn’t heat,checked breakers they’re ok,same with heating element,and thermal fuse, limit fuses.What else could it be
Check if there is 120 VAC at the motor centrifugal switch (terminal 4 - red wire). The dryer should be plugged in and off at the test time.
If the reading is wrong, check for 240 VAC at the dryer wall outlet.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174285&diagram_id=1363116
