No Power to Whirlpool Dishwasher
My dishwasher quit working this morning for no apparent reason. I used it last night with no problem but today it has no power. I’ve checked my fuse box and it was fine. Also, I pulled the dishwasher out to check the power cord and there was no problem there.
Does anyone have any suggestions?
Check the box under the dishwasher where the cord connects. If you have power there, the next place to check is the door switch.
So as the topic says when i turn on the washer to clean my clothing the washer makes a clicking sound for a while and then shows a error message F-. I just switched 4 hoses and a bellow for the machine and the laundry pile is getting high so if you can help me please do:p
Gene said:
What was shown after "F"? It suppose to be two digits.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5160289
sorry it says 22 afterwards, alright, I found out that the strike is broken or the piece behind the strike is broken. Now, I don’t think the control panel is reading that the door is closed so if you can help by giving ways to get the door open or a clear definition of what F-22 means, thank you.
This is now kinda like my main thread for my washer. So, stupid me though it was a good idea to do necessary things when replacing the hose, i knocked off a plug, put the plug back on and door unlocked. Now the drum won’t turn/overfills :eek: looked through the Tech Sheet and tried most of the things but idk where the pressure hose is. Also that "pointy dial" on top of the dispenser is stuck on the numeral 1.
H8 this washing machine
Hopefully the attached file will help you.
this ^ didn’t really help because I had some people come and look at my washer and they said that it was the switch. So to restate restate my problem:
When I try to use both the heavy duty and the normal wash sequence the switch Part Number: AP4365357 moves to the corner and back to the first sequence and then the water just doesn’t stop flowing and nothing else works. Would the root of this problem be the flow valve or something else? Thank you for helping me with this.
Did it show any error code?
Did the washer overfill?
No error code and if i didn’t stop it wit would have overfilled
It is strange why it did not show any error code. You may want to replace the pressure switch.
figured it out it was a hose that connected from the pressure switch that was off. I am seriously getting tired of the pets i keep at home, so now its a F-20 error and i am going to replace the hose that the pressure switch connects. $10.00 for a hose!?!?!?!?!
