oven doesn’t work everything else does. Was told it was the oven control board. also said i would have to by the clock timer which still works, can anyone help.
J
Hi.
If you not getting 240VAC to the bake and broil elements then the control board/clock assembly should be replaced
You also may need the overlay 316220701
Here are the breakdown diagrams and http://www.appliancepartspros.com/backguard-parts-for-frigidaire-fef336fmc.html
Post the results.
Simon.
