neither bake or broil elememts heat. control panel appears normal.
Kind of unusual for both elements to fail at the same time. Pull out the range and test for 220VAC at each element witha bake/broil selected. If you don’t measure it there, you probably need to replace the clock.
no voltage at bk. or brl. terminals. have 246 across L1-L2.
L2 out is also dead.
Sounds like the clock is the culprit.
