Apologies! The model number of the washer is: WBSR3140DAWW, I put in the wrong one (n00b mistake).
Washer fills and agitates, but won’t drain or spin. When looking at replacement part, it looked like this was a "clutchless" model with an electric pump, though I may be incorrect.
So, if it agitates, why won’t it spin? I am trying to understand the relationship between lack of spinning and draining, since we know it does agitate. Is there a switch that stops the spin, if the pump is not operating? If it is an electric pump, then maybe it is clogged/impeller or just DOA? I am planning on checking for obstructions at the pump itself
Any other thoughts here on what to check/fix?
