LQQKING FOR HELP 3yrs old and water in door works fine ice maker make ice great but the ice won’t come out the front so i test motor and soleniod test great no frozzen ice stopping it from turning so what am i missing any help what failed on the ice delivery system input please thank you all for info \markiee43@yahoo.com:confused: GENE CAN YOU PLEASE HELP ME THANK YOU
Part 365 in diagram 7 is what the motor turns which in turn turns the augur. If your motor is turning but the augur isn’t that part must be slipping on the motor shaft. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5226993
AUGR WON’T TURN AT ALL ITS FREE BUT THE MOTOR IN THE BACK WHICH TRUNS THE AUGR TO FORCE ICE OUT THE DOOR WON’T MAKE THE ICE COME OUT OF BUCKET TO THE DOOR ICE MAKER IS STILL MAKING ICE AND THE WATER ON DOOR WORKS FINE BUT WHEN I WHICH TO THE ICE BUTTON NOTHING HAPPENS ANY HELP THANKS:confused:
