slow spin
I have a GE washer that had been working great. Then it started spinning slower, and the water is not spun out of the clothes. I checked the belt and it is still tight. Any help would greatly be appreciated.
Hi.
Please post the complete model number of the washer.
Simon.
Sorry, but I just located the model number, which was in a very obvious location. The GE washer model number is WBSR3000G2WS. Now it is whining some, like the is to much water in it. Thank you
Hi.
You should check the drain pump and hoses for restrictions.
Possibly the pump is bad.
The drain pump WH23X10013
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5554928
Thank you.Post thew results.
Simon.
