One element stopped working entirely a couple of years ago. Now that another element has stopped working it’s time to repair or replace the unit. In both cases the "on" light illuminates but the radiant element does heat when the respective selector is turned on. The unit is eleven years old. The heating elements cost about $100. each. It is a granite counter top drop in unit without any appearant mechanical installation fasteners.
My questions are: 1. Is the problem the heating element or some other component. 2. I am reasonably handy and have a nice selection of common tools; should I attempt the repair on my own. 3. If a self repair is appropriate what are some guidelines that should be followed.
Thanks, Mark
[QUOTE]…My questions are:
If a self repair is appropriate what are some guidelines that should be followed…[/QUOTE]
Mark,
It can be a bad heating element, infinite switch or wires. You have to figure it out by performing some continuity tests.
I do not think it’s going to be too difficult.
The access to all parts is from the bottom, so the most difficult part of this project is going to be removal of the cooktop from the cabinet.
Let us know when you ready.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232464
Gene, I have the unit (CER30QB) out, inverted, and the bottom cover is removed exposing the controls and wires (unit is unplugged). I have a meter for checking ohms, etc. All of the wires appear normal, connected and intact. As I said before, the two front burners are inop (they stopped working at separate times, more than a year apart) though the red "on" indicator lights illuminate when each control is turned on.
Can you tell me which wires I should check for continuity?
Mark
Mark,
All tests should be done in accordance with the [How To Check Continuity With Ohmmeter](http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=193326&pkw_=basket&model_id=232464&NewWindow=1"]wiring diagram[/URL].
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - [URL="http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html)
Mark,
Some times very strange things happens without any logical explanation. It happened to me as well. One of possibilities: it was a loose wire somewhere. Hopefully it’s gone.
