[SIZE="5"][/SIZE]
My GE washer had a broken belt. I replaced the belt and it won’t agitate properly. It will flash 4 lights which mean faulty with the mode shifter coil. How do I repair this and how much? Is it worth fixing? My washer goes through the cycles it will agitate and the inner tub moves at this time is that normal? It will drain, rinse, and spin out ok.
