Washer does not drain
The washer fills water, spins, and stops at the start of the rinse and 2nd spin and does not drain. I hear a small noise and the Rinse light is ON. After a few minutes, the noise stops and the light goes OFF.
Can you please let me know what to check?
Take off the front by inserting a screwdriver into the gap between the top and the front near the edges, which will release clips holding the front on.
You can now examine the pump while the machine is supposed to be draining. If it is not turning, check the wiring and test for current getting to the pump. If it is, replace the pump.
