Recently my washer has been "not working" as my g/f said. When I looked into it I noticed that the machine will fill up with water and then just sit there while the control would just click clockwise and then once it gets to the "drain" cycle it would drain. It completely skipped the agitate and spin cycles.
I messed with the switch during the agitate cycle and managed to get it to work for 10 seconds and then it shut off. I did the same test with the spin cycle and it did the same thing. I bypassed the lid switch and it did the same thing on both cycles, so it is not the switch. I haven’t looked at the fuse, but I assume that if it were a fuse it wouldn’t work at all.
My assumption at this point is that it’s the motor and it’s over heating because after I wait for a minute or so I’m able to get it to agitate or spin for another 10 or so seconds. The washer is fairly old so I’m not sure if it has the LED indicator lights. My g/f says that it’s not working so we have to get a new one :eek: But my cheap side won’t let that happen. lol Thank you.
