Washer won't spin or drain
My washer will not spin nor drain, I can hear something when it is put on spin cycle but it will not move nor drain. I don’t know what part i need to replace to fix this. Please help ASAP!! I have 5 kids and can’t afford to not do laundry daily.:slight_smile:
What is it that you are hearing? Is the timer buzzing or is it the motor humming. Motor is at bottom of washer. You may have a faulty lid switch but that usually means the washer is silent after agitation stops.
Eric
