whirlpool electric oven fault code e3 f2
showing fault codes e3 f2 and beeping won’t turn on. please tell me what this means and what i need to do to fix problem
"F2-E3" error code means a shorted key on the key panel. The correction is to replace the control panel. In order to provide the correct part number we need the color of the control panel.
Here are the break down diagrams for the Whirlpool oven http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=23469&&model_id=239610
