F3 - E0: Oven temperature sensor (RTD) opened (upper oven, if double oven)
F3 - E4: Oven temperature sensor (RTD) opened (lower oven, if double oven)
After about 15 min of use, my oven would beep one of the above codes and then shut off. So, I replaced both sensors in the oven. After replacing the sensors I can get about 45 min out of my oven before one of the codes beep and it shuts off.
I thought I remember reading someone where that the next step would be to replace the control panel/board? Does that seem right?
Yes, it could be the control board.
But before replacing it I would check the connections of the sensors on the control board.
Check that they are clean.
Check for a cold solder joint on the connection and for a crack on the copper track.
A magnifying glass will help here.
Cold solder joints are often a duller gray and/or have pinholes.
Also gently wiggle the connector while watching the solder side of the board to be sure that the connector leg does not move in the solder.
