I just inherited a Whirlpool Ultimate Care II washer, p/n 3954205. Supposedly it worked perfectly before I picked it up, but now it will not agitate. It fills, spins empty, but doesn’t agitate on any setting. The washer just makes a humming sound for 30-60 seconds, then stops making noise…after a few minutes w/o me doing anything, it’ll repeat (noise for 30-60 sec, then nothing). After a little while it smelled a bit like something was burning.
I checked the coupler - it is not broken on either side. The door switch is fully functional. I pulled the agitator dogs out, but not really sure how to tell if they’re worn or not. Since they’re so cheap I’m going to pick up a set of replacements, but what else should I look at?
My research tells me the timer could be a culprit, but wouldn’t that affect it’s operation all the way around the "circle" of time? If it fills and drains, the timer should be fine…?
I didn’t notice any chaffed wires when I had the thing apart either.
