The washer fills & washes but won’t drain. It never gets to the spin cycle. We’ve replaced the timer & pump. Any suggestions? I’d hate to replace it, but don’t want to keep putting $100 at a time into it to replace parts.
Thanks,
Bonnie
Thanks,
Bonnie
Check the lid switch. Bad (open) lid switch, no drain/spin, timer won’t advance.
Eric
Thanks. We bought the lid switch (AFTER buying the pump & timer, because we listened to my brother the genius instead of your forum). I’ll let you know if this solves the problem.
Thanks to everyone who offered input. I wish I’d come to this forum FIRST, before allowing my husband and brother (who are both wonderful, but were off-base) to diagnose and "fix" the washer. The lid switch repair did the trick, but I had already purchased the pump and timer (because my husband and brother were each sure that one or the other was in need of replacement).
