Washer washes fine but when it gets to the rinse cycle it stops working , I replaced the timer $135 still, when it gets to the rinse cycle it stops working , I was told to replace the water inlet valve, Replaced it $20 Still, when it gets to the rinse cycle it stops working, Any ideas?
NOTE: After reading other posts in the forum I checked the Lid Switch and it is broken, I taped the wires together and problem solved, it is the lid switch. I just wish I would have figured that out $155 dollars ago. Now I need to invest another $27 on a new switch
— Begin quote from sidfink43;575827
Well glad you got it fixed. Any competent repair person should have known to tell you to check the lid switch as the first thing. The inlet valves is a total non-starter, don’t know why you were told about them.
Sorry you had a bad experience, but at least now you know how to repair this machine.
Good luck going forward
I have the same issue, replaced timer twice, wired the lid switch together, all cycle work except the rinse cycle. Any suggestion?
— Begin quote from recon1965;761052
And yes, I can verify unplugging before touching wires, burnt my trigger finger, now that was a dumb move, haha
