OK, I know that my washer is 19 years old, but if I can fix it for less than a third of what a new washer (albeit the new ones may be better and more efficient), than I figure it is worth it (unless someone more experienced can make an argument otherwise).
The last couple of times it was used, I noticed a slight electrical burning odor. I could not tell where it was emanating from, but I figured the motor was the place to start. I took off the cabinet and tested the starter switch and the motor as the repair manual indicated. Everything tested fine until I checked for shorts to the motor case. There my ohm meter gave readings in the magnitude of about 8 MILLION ohms between the case a few of the wires from the motor. New motor, right? But then I went back and tested again and got no reading. So what does this tell me? Do I need a new motor or not?
Second question - I removed the agitator and the tub to clean out all the stuff that accumulates over time and found that the porcelain in the center tube of the tub has chipped and the underlyinf metal has rusted a bit. No holes rusted through and the metal is still thick and strong as best I can tell. Do I need to replace the tub with a new one or is this "normal" and will last many more years? If I don’t need to replace the tub, should I try to seal the bare spots with epoxy or is that not necessary?
Thank you for any assistance you can offer.
Gary
