will run fine untill the final spin cycle. It seems the drain pump is working but the drum will not turn. HELP.
Look inside the lower service panel for some tech notes that will allow you to put it into a diagnostic mode.
Given the it spins after the wash cycle, it seems mechanically it is ok, so I would focus on the motor/speed control board which is the weakest link in the chain of control on this model.
