Can’t get the back panel removed to change out water valve. Two clips at top (and who knows what else) are holding it in place, and I don’t want to break anything trying to force it up and out (already cracked my head on the shelf above the washer).
The back panel DOES NOT COME OFF!!! Put it back together and start over!!! Remove the end-caps on the console, remove the 2 screws and roll the console over backwards, remove the 2 clips, The whole cabinet will then come off!!!
Inlet valve is installed. Operating fine, except something I did made the washer not operate on the regular cycle. Only operates on Permanent Press. What did I do, and how do I fix it?
Checked all wiring, and everything is in place. Timer switch moves after filling tub on regular cycle, but no agitation occurs, so something is hinky somewhere over there. Washer works just fine in all cycles on Permanent Press mode, so we’re just going to use that for all of our clothes washing needs.
