Frigidaire front loader will not spin
Frigidaire front loader will not spin, but it will go through all other cycles and pumps out water.
im not sure the machine should fill with the door open ?
Frigidair has a fine chain diagram for this failure in the service manual underneath
It includes checking the soap dispenser magnetic switch, the timer contacts and the door latch. Door latch must lock before spin is enabled.
I have a Frigidaire Refrigerator with the Freezer compartment on top. We bought it brand new at Lowes about 5 years ago and has run fine since we have had it. I opened the freezer the other day and everything was melting. It was not producing any cold air in the freezer or the refrigerator. I turned the temperature control setting in each compartment up one notch in the colder direction. After a while it started getting colder. It reached normal operating temperature and lasted about two days. Now it is doing the same thing, it is not cooling anymore. Any suggestions?
Gas Dryer runs but no heat. Checked coils, Igniter & flam sensor they are all good. When I turn the dryer on the igniter doesn’t glow?
It could be the thermal fuse, that is located in the back of the dryer. Unplug the dryer, and take the back off, and you will see the thermal fuse, it is white in color, and it is a inch and a half long, and a half inch wide, and has 2 wires coming to it. If you want to do a quick check, you can take the two wires off of the thermal fuse, and put the two terminal ends together, and put some tape around them, so it does not hit metal, and then turn the dryer on. If it heats, replace the thermal fuse. if not replace the ignitor. DO NOT run the dryer with the thermal fuse jumped out. The thermal fuse is between you, and burning down the house. If you need me you can reach me at my web site at http://www.applianceeducator.com Tom
