frigidaire not going into high spin
I have a frigidaire front load washer that is not going in too high spin it is doing every thing that it is suspose too except the high spin what is causing this porblem?
The first thing I would do is unplug the washer, and take the back off, and you will see the pump. There will be a fat hose coming down from the tub to the pump. In there, there is a filter. If the pump is clogged up it will never spin at full speed. If you do that, and it does not work, replace the motor control board. If you are in the back of the washer it is the white color assembly on the back right hand corner. Tom http://www.applianceeducator.com
