Whirlpool Duet Won't Start
whirlpool duet GHW9100LW1 - Powers up will not start…led flashes on wash cycle selector…Downloaded the job aid :
1.Completes entire diagnostic test ok
  1. Checked continuity on all components: door lock solenoid had high reading…replaced lock assembly.
  2. Reseated all connections.
still will not start
What next? CCU or Touch pad Assembly
Well, you have already done what I would recommend, so I think you should go through the trouble shooting on the CCU in the manual.
Here is the manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Good luck, and let us know what you find out. I am guessing it will be the CCU because like the butler in the mystery stories, it almost always is.
I cannot run the diagnostic test i followed the directions and the time for 2 min just blinks…any thoughts?
I have the same issue did you solve your issue and if you did what should I do?
Mikeheff
Please start a new thread and post your model number and a more detailed description of your problem and someone should be able to help you.
