this dryer calls for a 5 prong cycling thermostat vs the common 2 prong . i have replaced all fuses/thermostats and still no heat. my main question is in the schematic it shows the 2 prong cycling thermostat vs the 5 pronger. help me wear warm clothes again!
Here are your parts, includes a wiring diagram.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDE3706AYW
The cycling thermostat should be 5 connector, see Item 27 in Section 1.
If you click on the picture a new page will open if you look closely at the back of it you will see the 5 connectors.
For the thermostat contacts it has a common, a normally open and a normally closed, shown as the CYCLING THERMOSTAT on the wiring diagram…
It also has 2 for an internal heater, shown as THERMOSTAT HEATER on the wiring diagram.
The normally closed contacts should be closed (0 ohms) at room temperature.
Have you checked the power to the unit. The motor runs off of half he line (120 volts) but the heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
